jwlandry
A few extra threaded ports would be nice
Awesome work! cant wait to see it.
The tank itself looks great... but the sight tube looks like an afterthought.
I know this is just a 3D model but IMO the plastic push-loc fittings with a bit of plastic tubing are the weak point of the design.
I like the sight glass versus the exterior tube. Also at least 1, 1/2"FPT bung would be nice for those of use that are returning coolant directly from the oil cooler rather than a tee in the heater line.
How do I know the head sealing design on the 6oh sucks horrifically with no real solution?
When people just give up and decide it's easier to beef up the poor degas bottle so it can take a better cylinder pressure pounding, because the heads will never seal...
Dang.
Use 2 site glasses, 1 at the min level and 1 at the max, or an oval site glass.the problem with a site glass is some trucks run lower coolant levels then other trucks, they arent all exactly going to be in the glass.
Looking good john.....have a couple builds coming up would like to maybe see these make it into the build sheets.
I'm in for one. My stocker is cracked.
Looking good! :thumbsup:
Do you have any idea on price point since there aren't a ton of these on the market to compare to?
I agree with this. Looks out of place.
I was also hoping to see a cleaner looking sight glass application.
Yes, I really don't care for the sight tube on the can. I actually don't care for those types on anything. Radiator, oil pans, fuel tanks. They alway seem to leak/seep after a while. What about a sight glass that's used in a lot of radiators in the industrial market. I'll see if I can take a picture of what I mean today during work.
This one uses a sealing washer for the threads but their are some that use pipe taper threads.
This is a cummins power generation part number of the sight glass.
130-7032 sight glass
A053f562 washer fiber
Just an option to think about.
I don't think I would buy the tank if it the final design has the external fittings and a site tube like the 3D drawing.
Dang.
