Absolutely zero traction
Daddyusmaximus
exactly. not a mud tire.
i also went toyo m/t's and i am shocked at how poor they are in the snow.
Compared to an AT or snow tire, yeah, but for a mud tire... not bad. At least my truck likes them on Indiana snow. I also drive slow and easy. (I'm old) Got the MTs for where they can get me on the trail.:rockon:
oilburner
west desert of utah
Wide tires and no weight doesn't help. My experience with BFG ATs is always good in snow. (02 grand Cherokee, 90 Toyota 4x4, 93 f250 rclb)A little less pressure always helps too. My current truck (f350 cclb) has old MTRs that do real well. But I still put some weight between the tailgate and the rear axle. I work in the sand and gravel/asphalt business so sand bags ain't hard to come by. Besides my dogs like to stand on the stack when my below the rail toolbox is slick. haha
taterthedog
Canada
Not too wide on a heavy truck I don't think. I level the box of mine with snow. That helps. There's all different kinds of snow too. Wet sloppy snow is very slippery. Regular snow that is cold, well below freezing, has pretty good grip.
oilburner
west desert of utah
I wasn't saying the tires are too wide. I was just saying that a large contact patch especially with added power is hard to keep hooked up. Weight in the bed will help. I would think that it would take a heck of a lot of Utah snow to add up to any weight at all. The old snowplowers trick of weight behind the axle is the ticket. It takes less weight because of leverage. There is a lot of info on plowsite.com about snow driving and weight.
GreenMachine
RI
Goodyear dura tracs are unstoppable on my truck. And mine are not skinny and narrow by any means.
79jasper
skiatook, Oklahoma
I like my cooper discoverer a/t's.
Of course just an obs psd, so not a lot of power, but would spin if I wasn't careful. (F350 sclb flatbed 7k lbs empty)
Sent from my USCC-C6721 using Tapatalk
Daddyusmaximus
Have yet to talk to someone that runs them, but I've read good things about them. I love to wheel off road, so I needed something with some sidewall grip for when I air down. I almost went with the Goodyears.
you have to run duratracs very low on pressure to get them to unload mud.
GreenMachine
RI
I have probably 25k on mine and they still look about 80% I would say. I run them at 55 if I recall. Mine are 305 55 20.
taterthedog
Canada
Just got a set of Duratracs to try myself. 325/65r18s, spiked and all.
GreenMachine
RI
Sweet! You will love them. Mine came from the factory prepped for studs with the little holes for them, but we don't receive enough snow to justify them. Plus they are way too expensive to only run as winter tires.
