I converted my 97 to electric fuel about a month ago. Everything went smoothly, and the truck runs great. No leaks and 65 psi of constant fuel.
I am using the usual Aeromotive regulator with 6an fittings. Pressure at the regulator is set at 65psi when running. After shutting the truck down, pressure drops to 50psi within seconds. And in at least 15 minutes the pressure will drop to zero.
I know these performance regulators won't hold pressure like the OEs do. But do y'alls regulators bleed down that quickly?
