What's the issue with the van ipr?
There's probably no room lol small hood, tight etc
Oh. By doghouse you meant through the opening into the cab, that's already removed. This used to have a big utility body on the back. There's nothing left of the body except the roof and doors. The doors had to be ratchet strapped when it was trailered.
I thought by doghouse you meant the ccv thing on the valve cover.
Get to it then! I'm sure they'll let you borrow the IPR. Start with that first asap and report back.
How will you know that the u pick parts have working iprs, you will probably be back to square 1.
I was gonna get as many as I could but every one of the 15-20 7.3 or t444e motors they had were stripped of the hpop, hpo Rez, and the gear and gear bolt. Every single one.
If you send me your address and cover shipping. I'll mail out my spare. Just ship it back after you find out if the IPR is the problem.
If you dont have an ipr on hand, you need one anyway. As well as an icp sensor..
How does the connector/harness look? My "no start" was a result of this, hidden under the split loom![]()
Rusty
