Air dog water drain???
Strokin6.4
Ok so here's some specs... 472, 60% nozzles, ii pump, airdog 2 165, pistons, valve springs, push rods ect.. Last time I ran my truck was sunday. Got in it yesterday, start it and it blew white smoke for roughly 3 second then gradually cleared up. Felt like it was running a little funny. Figured big nozzles... maybe normal after sitting. So get in today fired up, same thing but not as much white smoke... both days I drove 45 minutes and fired up afterwards fine. Seems like only when it sits. I'm thinking maybe I have some water because I've had the airdog for 14k and haven't touched it. Same goes with the top fuel filter.... kinda been blowing it off because I'm suppose to get a reg return. Should I just go out and drain it or maybe let it sit over night then drain it and start it and see if its there? I plan on changing filters but idk if that would make it smoke on start up.
dommel01
travis i drain mine like once a month, all you have to do is loosen the like almost star looking thing, really easy takes a couple seconds, idk if itll help your problem or not though
Strokin6.4
You ever have this after sitting a couple days? Some seem to think its just the big nozzles from sitting. Obviously its got something to do with sitting but today in only sat the usual day inbetween starts.
dommel01
no mine never smokes white, it does smoke alot when started after sitting for awhile but its black without a hint of white
GROSSpolluter
So Cal
could be condensation built up in the intercooler. my nitrous line was full of water when i removed it.
