Air to Air Intercooler Upgrade
SickSeven780
I'm in the process of building my air to air setup now for my daily driver while keeping my stock primary radiator. I'll post pictures when I get further along.
Cody,
Are you removing the secondary rad? if so are you running air to air coolers for the tranny and fuel? ******** the secondary water pump?
Codydiesel
West palm beach, florida
Yes I am removing the secondary cooling system completely. Running air to air fuel, trans, and intercooler. Secondary water pump will say in place with just inlet and outlet connections trimmed off to make more space from my hot side pipe.
bigrpowr
<How I Fly
Administrator
sounds fun ! keep us posted ! i'm gonna see how far the air to water wil go on fuel .
SickSeven780
Is there any risk to keeping the secondary pump in place but not being used? What I mean is does the coolant cool and or provide lubrication properties to the bearings in the pump. My concern is that if I run it dry that it could cause issues. Would you be able to PM me the tranny and fuel coolers you used so I can utilize them on my build? Did you remove the OEM tranny and fuel coolers or leave them in place and just add an aftermarket cooler into the circuit?
Thanks for the info!
