GROSSpolluter
ok my truck somtimes does not want to start. and it throws a code fuel pump circuit too high. but if i clear it and start it right after it fires. but its a no crank no start issue and i check codes comes up as that one. but is that because i dont have the stock fuel pump hooked up or is it becuse the fuel pressure is too high? i also dont have the airdog wired up to the oem plug i used a key on source in the fuse box under the hood...what do you guys think?
