- Joined
- Oct 3, 2012
- Messages
- 11,853
- Reaction score
- 39
Ive been on stock suspension up until recently. Rode on the stock 275s for a long time and then threw on some 325s. Went to get an alignment and had the thrust angle adjusted as well as toe and centered steering. Anyways you could visibly see the wheel stick out more on one side.. Theoretically alignment shouldnt change. Maybe bigger wheels accentuated a factory flaw. Ill see if i can dig up some alignment sheets. Mine wasnt the first time ive seen or heard of it.
or just made it more obvious to your eye... just because you didn't have your alignment checked until you put new rubber on doesn't mean it was accurate with your factory tires. no one is saying Fords alignment is perfect off the lot.
