TXGLASSMAN
Okay... So maybe it's a supercab thing or a 2012 thing but my brake cable does not look like it needs to be moved using the special bracket... In fact the diagram in the instructions doesn't even look like what my cable system looks like. And also the step arms go in the first and second holes under the truck right? Bc there is a spot in the far back that it could go as well...
I didn't move my brake cable and you go the 1st of holes for the brackets or the 2nd set either way the boards will mount anywhere you but the arms
