powerstroker66
hi all, i have a 2000 f250 7.3 auto that doesn't have the lift pump kick on with the key. Truck starts and dies shortly after (obviously). Jump 12v to the pump its fine. Inertia switch isn't popped. All fuses are good. Relay is good. Power to both sides of the fuse. I dont have power at the green/yellow wire at the inertia switch. After tracing it back to the realy block, ive concluded that i have 12v at the trigger wire but dont have power to the blue/orange wire coming in that relays power to the green/yellow wire when the relay or key is turned on. Does anybody have any tips or ideas on were that wire traces back to or gets power from? i do not have a schematic. If i cant figure out soon i might just jumper in 12v from a key on fusible source but trying to fix it right first. Any help greatly appreciated. Thanks!
