CDUBYA
- Joined
- Jun 13, 2011
- Messages
- 193
- Reaction score
- 0
Hydro dipped?
It is very easy to take off. you just pop the 2 bottom plastic pieces off, the 12 V and the sync piece. then under there is 2 8mm bolts that need to be taken out. after that you just simply pull on the whole piece and it unclips. You can then see all the plugs that need to get taken off in order to actually seperate the piece from the truck.
Takes only about 5 minutes.
