i have therm on my 6L and love them, they flow better, spool the chargers better and i've dropped almost 10psi back pressure just with the manifolds
So one might look at mani's and up pipes over a waste gate based on the drop in BP and benefits of each?? Esp. since a WG isn't needed on mild builds?
With a drop in back pressure (due to the same volume of exhaust in a larger space) the speed of the turbos *should* drop a bit, lessening the need for a gate. Does that make sense? Basically, since the volume of exhaust stayed constant, the lower pressures created by larger area, is easier on parts. At least that's how it makes sense to me.
