They make the standard ARPS which nearly everybody uses and they around $500. They also make ARP 625s which can hold 260,000psi instead of what standard ARPS can hold which is 220,000? My numbers may be off. But the 625s cost over twice as much as the regular $500 ones and are supposed to be stronger. As far as H11s being better, that's been debated over and over. If ARPS are properly installed and everything else is in check they can hold well over 800hp. Both will get the job done. But like I said before even if hes practically giving them away I would rather spend the $500 for new ARPs and not worry about it.
