Auto Enginuity Question
Zmann
U can muddle through it
you will never be truly proficent unless you know what the values of a good system are like ICP,oil ETC but you can always data log and ask on here
hawgdoctor
king george, va.
Mine runs on an older acer, and not one problem. No sense in spending big money if you don't need to.
Sent from my DROIDX using Tapatalk
05wh250
hendersonville, nc
This is an old thread but i'm looking for help with my AE.
I'm trying to figure out how to change the setting for the speedometer on my 05.
I'm running 315/70/17, my sct won't go lower than 600 rpm's and all the calculators I find for tires show it needs to be 586 rpm's. Can anyone guide me through it or have a link for it?
I tried google and read through all the threads I could find on here but didn't find anything.
MrOneEyedBoh
The tire changing poriton is under the ABS/brake section. Its kinda weird. What I did was select a tire size, then test drive it. My tires are damn near 35s. But the tire size that AE had most accurate was I think 33-34s? Cant remember. But all in all, I used my GPS to give me my speed, and then I matched it to my speedo and adjusted in AE accordingly.
I forgot what the speedo accuracy is anyways.. It can be off quite a bit I think.
