B2A20 code
Tree Trimmer
I have a 2010 F350 lariat.
Driving down the road, had a squeal like a pulley locked up or flipped a belt and the truck died rolling down the road.
Pulled over, looked under the hood, and under the truck, all the belts are there, and all the pulleys turn.
So, I pulled what codes I could get from it. U0253 and a B2A20
Currently, I have a crank but no start happening. No funny sounds, fuel pump kicks on, after I crank it I can put it in drive/neutral as I drug it back to the shop with another truck so the fixes I have found on the internet do not seem to apply to me.
Wondering if someone has had this, and has a solution or a place to start.
I have had this code before, and I fixed it before, but for the life of me I cannot remember what I did to fix it.
clean and reseat your pcm connectors. Also check the connectors on the drivers side fender. I attached another troubleshooting guide that may help also.
  • B2A20 - 2009 Ford Truck F 350 4WD Super Duty V8-6.pdf
