Bare minimum wiring to run a 7.3??
Bremen, Ohio
No matter how you do it its gonna be a PITA! We've done both harnesses, no pics sorry. Just trace down each fuse coming from the fuse block that you don't need and delete it. You'll be surprised how little it takes to run the truck.
If it were me, I would do as Jason suggested and use an SD harness, 4R100, and a PCS Controller for the transmisison.
Just my .02
vanderchevy18
Benton, Ks.
Thanks Ryan! I'd appreciate it!
I would like to eventually run a PCS. Especially since you can run paddle shifters with it! Lol! You can't talk me out of this one Jason! LOL
Nate I don't mind the work too much. I'm just excited to have a billet engine finally so I can get the full potential from these injectors!
Hotrodtractor
Mingo, Ohio
Do what you want - but paddle shifters will not make you faster or more consistent.... both things that are nice in a race truck.
vanderchevy18
Benton, Ks.
I will do pretty much anything you suggest, but I'm gonna get one eventually. Lol! I've always wanted one in a truck and I can't do it in a superduty. I can with the 78 steering wheel. Not giving in on this one! LOL
Hotrodtractor
Mingo, Ohio
The first rule of a race vehicle - it doesn't need anything that doesn't make it faster, safer, or more consistent.
So do you want to race - or have "cool" buttons? :D
fordfreak4life
Pretty sure you'll need to run a 4r100 if you switch to the SD stuff. Food for thought.
I have a complete factory wiring diagram book for a 1995 if you want it. Pretty sure its at my dads. I'll be back there on the 8th for Equifest.
Ur coming to leoti the wkd I'm gone
yotaneck13
Get a full harness. And a 4x8 sheet of cheap osb. Lay the harness out on this. Every place a plug branches off of the main harness put a nail oe screw and wrap that part out and pin it tight. This way you can strip the harness tape and casing. When you rewrap it. The legnths of all the wires will be exactly the same. And nothing will come up short.
sent while looking at my sled. since theres no freeeeking snow!!!!!
vanderchevy18
Benton, Ks.
Yes. I want 1 cool button. I told you I'm winning this one! :p:flipa:
Its cool Ryan. I'm gonna put the built engine in my white one till I get the 78 done. At least that way I'll have a truck done for TS. So if I take a bit longer to get it right its not as big a deal. Just give me a holler when you head down!
Strokersace
Towanda, KS
No, just to Wichita that weekend. Not sure when I'll make it out west again. When I do though, I'll let you know.
Will do!
Hotrodtractor
Mingo, Ohio
Winning? If I was farther along in parts gathering I would show you who would win :D :poke:
(Please excuse the old pics - this has yet to make the journey to the HRT R&D Compound...... :D)
fordfreak4life
Not being gay, but I have massive wood right now, please tell me u r going to mechanical pump it
