Mavericktkw
id like to see a batMo wheel in a tow power atmospheric turbo
...and I'd like a golden toilet, but this will never happen unless batmowheel is proven to be better than precision billet. Then if it actually turns out to be a superior wheel, I'll rob you for your royalties off the idea, and buy my golden toilet.id like to see a batMo wheel in a tow power atmospheric turbo
tranny=goodwell based on what iv seen so far it seems the batmo really shines at bringing out power down low in the rpm range, im about to get about 8k ready to drop in this next fall and wanted something like that with empires billet heads and im saving up this summer for a built tranny this summer.
I'm REALLY looking forward to the results. no matter the winning turbo of the testing, there will likely be a superior design, and a clear direction for the best air flow.Remember that the towpower atmosphere charger doesn't use a cast wheel, it uses a precision turbo designed wheel so don't assume that there would be any power gain. We are actually getting ready to start testing a bullseye s475 double batmowheel against a 75mm precision turbo to see which performs better.
Rudy: I'd love to see stock vs. batmowheel turbos on the dyno- same truck same dyno, same day. Please be sure to let us know if you ever make this comparison.
He just did this yesterday...
Batmo gained 50 over stock and then the billet 71 only gained about 20 over the batmo for an extra 900 and bigger turbo
As for it being a "cult"...I'd take 50 horse for a 400 dollar part vs 70 for 1300
All the nut swinging around here is getting old lately
Link
http://powerstrokearmy.com/forums/showthread.php?t=9031
The difference isn't just peak power. Look at the curves. Way more power under the curve with the 71mm and way more power potential. That extra $900 is more than worth it to me.
ok, thats great but for someone that just wants a little jump to mid 600s, like a lot of the goals on here the BatMo is more than worth it.
If you dont plan on ever adding fuel to a set up and want a nice bump in HP....id rather pay 400 any day
the average power is about 15 hp more throughout the curve and does extend out further, but i cant justify that much more $ for that benifit
When your alreadybl paying a substantial labor bill its not that much more
The labor is there for both set ups though..id rather take that extra 900 add 100 to it and buy a ported intake manifold
Your also getting a whole new turbo rather than just a replacement wheel...
And if your already spending 6k for studs Ect (mostly labor) an additional 900 for a rebuilt turbo makes more sense.
Its all going to come down to what the buyer wants and needs
I guess we just have different thoughts on this
But the 6k, unless you're doing a full EGR delete with a gate, buying the studs, an airdog 165 and the fuel bowl delete block, and then adding in labor you're not going to hit 6k unless you're getting screwed
Thanks for the link. it was a great read. A big thank you too to Rudy's for the testing. I'm thoroughly impressed with all the testing resultsHe just did this yesterday...
Link
Really depends on what youre going for... if you want a sheet to show your friends that your truck made 6XX for X dollars its great. But, I think most guys are looking for some results at the track and on the street... the graphs suggest that results at the track would turn the tables as far as cost vs return.He just did this yesterday...
Link
