SkySki Jason
Pull the loom, etc off your old harness and try to ID a problem. If there is a short, you should be able to find it ohming the harness while wiggling it around.
BE AWARE the typical loom they sell at autoparts is not up to the task under the hood. I found some puddles of what used to bee loom in the valley of my old engine... Also, the 'cloth'-type electrical tape seems to do better in that environment than the shiny stuff.
You are welcome to send the harness back, no worries. I will find someone who can use it eventually!
Not charging AT ALL? What voltages do you see with engine on/off?
