bd new exhaust manifolds
kyle43335
just bought these.
we will see how they do. pretty cheap to
08BIGRIG
WI
I think that you will like these. They are said to flow a little better than the standard 6.0L manifolds. They are also built like a tank!! Keep us updated on what you think about them after the install as well as your first thought when you get them in your hands.
kyle43335
10-4
3brorce
Your saying the 6.0 up-pipes will work correct not the 6.4s.
08BIGRIG
WI
If you have a 6.0L engine you can bolt these right to your stock up pipes if that is what you want to do. If you have a 6.4l engine you will need to custom up pipes just like the regular 6.0L manifolds for these manifolds to work. Any of the aftermarket up pipes made for the 6.4l to use the 6.0l manifolds will fit.
Dzchey21
wyoming
yeah these are intesting for sure, the price is right, the construction is simple and looks like it should be strong. not sure how much benefit there will be with them but im interested to say the least.
kyle43335
mpd is sending me some uppipes to get the junk thats on the truck now, off.
once theyre on ill give my opinion. they will be on by the end of this week coming.
kyle43335
Stock.
barder is building me a 71/59 setup. im staying stock fuel so these should do nicely.
Sent from my DROID RAZR using Tapatalk
kyle43335
i just received these this morning.
they are nice. much beefier then the stock 6.0 manifold. the manifold looks like it will flow much better.
theres no casting flash inside them, the runners are very smooth.
the log portion is bigger. hopefully should be putting these on tomorrow
