BDP Stage 1 injectors and D66 turbo
fatsix
South Jersey
I just pulled these out of the truck this week.
D66 Turbo. Less than 1000 miles. No end to end play. The compressor housing was painted white, so I cleaned it up. Comes with modified pedestal and welded up outlet.
$1000 + shipping. No core.
BDP Stage 1, 160cc injectors. These were my original injectors that were completely rebuilt with new parts. 5000 miles on these. There is one bad injector o ring, highlighted in yellow. All the O rings were replaced 1k miles ago due to a bad batch (multiple pink/ middle o ring failures).
$900 + cores + shipping.
Close up of failed o ring.
Get both for $1800 + shipping + injector cores.
Willing to trade for: (cash to offset uneven trades in either direction)
Gen 3
Terminator Duals
Electric Fuel setup
Billet rods
Other high HP parts.
bad12jr
Just out of curiosity. What brand were the old o rings.
Sent from my x2 somewhere
fatsix
South Jersey
The old rings are whatever beans used. So I'm going to assume international. Replaced again with International.
The stage 1's are good for a healthy stock trans with a torque converter and VB upgrade. Anything more and the trans isn't going to last.
The D66 will handle 238/100 hybrids. Anything more and I believe you are on borrowed time.
These are just stock replacement upgrades built around keeping stock reliability as much as possible.
bad12jr
Thanks. The reason I ask is had another brand do the exact same thing.
fatsix
South Jersey
Just to sweeten the deal a little. I will throw in a 5 position chip from beans if someone would like to buy the injectors and turbo. Chip has stock, high idle, economy, tow, hot. I cannot find the little knob which is why i didn't initially list it. I will continue to search for it though. You can still change the settings, just no fancy knob.
Injectors, turbo and thumb wheel chip. $1800 + shipping + injector cores.
fatsix
South Jersey
Revised injector pricing.
$800 + cores + shipping
$1100 + shipping (no cores)
They are boxed up ready to go.
