caladash
I have 2 engines Im rebuilding and Im stuck on one thing before getting things started. I bought the International Service Manual DVD and it has all tolerances needed for a rebuild but im not sure which description to use for main and rod bearing clearance. Granted, the tolerances are the same! I would like to know what each one is describing.
Main Bearing to Crankshaft Running Clearance
(0.0018 - 0.0046 in)
Connecting Rod Bearing to Crankshaft Running Clearance
(0.0015 - 0.0045 in)
Connecting Rod Bearing Running Clearance
Also is there a solid number that is preferably liked by most? My machinist said 20 thousandths is a good number which is within range. Lastly, is this the tolerance check that uses plastigauge? Or is there a better way? Thanks!
