Best t-4 mount
baderic03
warren ri
Negative it's just bellowed up pipes with mount and plate for oil drain back. You will need to add the extras. Down pipe,bov,intercooler piping,turbo oil feeds and drain lines etc
2000wa250
When I bought mine it came with cold side pipe and downpipe as well. I in no way meant to knock jakes kit. As we all know every truck is a bit different and that shows sometimes in regards to minor fitment issues such as downpipe rubbing or not lining up with an already existing exhaust.
As far as the quality for the kits it is good. Love mine.
OBS Boysel
Circleville,Ohio
It came with everything, except intercooler pipes. It has the up-pipes in stainless and the mount and everything for arounf 8 or 9 hundred. Call Nate at Unlimited diesel (740)569-1319 I think he still has a few of them left. You will not be disappointed. Very nice set-up.
Cratos
ocala fl, area
irates DP fit needs to have the DP reworked, to fit the rest of the system.angle was all wrong for my set-up. inless your building the exahust to fit. I have MBRP 4 Inch system and it was far from fitting I had to take it to an exhaust place to get it to fit even after cutting the fire wall :(:( the rest of the mount went ok just had to shim the drain tube with 2 washers and bend the trans dipstick tube,
IC pipes fit good :)
mount is good
s366 spools good
dont forget you will need IC boots and clamps they are not part of the kit. :(
woodduck97
Maryland
So who makes a kit that I dont have to go modifiying when I get it to work in my truck? 1500 for a complete kit and I got to modify it doesnt make no sense.
Strictly Diesel
Phoenix
FWIW, I don't think downpipe fitment can be considered a factor. There is NO way any one person (Irate, Carson, TN, etc) can build a "universal" turbo mount kit and include a 4" downpipe and guarantee it will match up to every exhaust system out there. If it fits with MBRP, it won't fit with MagnaFlow or Diamone Eye, etc. Every single company does their downpipe different, so expecting the pipes after your existing downpipe to match a 4" downpipe from a different place isn't realistic.
As long as whatever mount kit you use fits along the firewall, and the downpipe doesn't hit the firewall, frame, or transmission, matching up the exhaust after the downpipe will be a necessary part of installing the kit. You might need to modify the first pipe after the downpipe to make it fit, depending on what exhaust kit you have and how it fits. That's pretty minor.
woodduck97
Maryland
im talking about fitting the down pipe down through the firewall. Exausht hook up can be easy. with a little flex pipe.
