Best way to drop egts
6foBAR
Looking to drop my egts as much as possible. I'm running mini max on hot (most current update). Airaid intake, 4"dp 5" straight after the dp. I set my de fuel at 1400*. If I get after it I spike up to 1450* way sooner than id like to. Also did anyone notice after the last updates any shifting issues. Part throttle shifts seem to flare the rpms before shifting. Thanks in advance.
Help out the air side of the equasion. Cold side pipe kit with intake elbow, ported intake manifold. Maybe a drop in atmo charger.
Custom tuning would help you a bit too... try Gearhead's MCC tunes.
3brorce
I would raise defuel to 1600*. 1450* is not hot. I couldnt stand the box HS trans strategy I had to switch back to my custom SCT tunes.
3brorce
Doubtful as low boost fueling is just that, at low boost. At full boost, low boost fueling isnt in the equation really as the truck is at full fueling if that makes sense.
6foBAR
Thanks a lot guys. Now what is the most effective? The intercooler tubes or the atmo. My thought is my egts will still be high if I just changed the atmo and not the tubes. Sorry if I sound like a noob but this is my first ford ever. Only had a few months just trying to figure this thing out the best I can.
jugger13
Elites 72.4 drop in atmo is hard to beat for upgrading a stock setup, especially on a cost-gain scale.
Great bang for your buck there
