Boost Gauge Needle Flutter Fix
Snoop
St Charles, IL
Auto meter Ultra lite my boost needle flutters whenever over 10 psi. I heard there is a buffer I can install inline. Anyone have any other quick and easy fixes or info on the buffer?
Pizza pig
MD
Some seem to have flutter and some dont, I dont. But you can use 1/4 OD line instead of the 1/8 OD line. That will get rid of the flutter, but you will need new fittings for the source and the back of the gauge.
Pizza pig
MD
yes, i usually use DOT airline because I have a huge roll of it from doing airride installs. LOL, but nylon works just fine.
Snoop
St Charles, IL
Installed 1/4" Nylon line, still tapped into the MAP sensor, and no more fluttering. Thanks.
Am I a chump for tapping off the MAP line instead of the intake elbow or manifold, or is it ok?
