Bought a 6.0
Short Bus
kansas
A customer of mine brought a truck in and after diagnosing a bad egr and injector he decided he wanted to sell and get out of the 6.0. I made an offer and he took it. It's an 05 f350 cclb dually with 150k miles. I'm into it cheap so I am gonna throw a few bucks at it. I'm planning on replacing the injectors with new ones from Full Force along with an egr delete, studs, sct dash daq thingy, intake and possibly a ficm. Anything else I should look in to?
Atsah
Maine
I don't see any need to change the intake, the stock unit works well in the 6.0.. Dump all the fluids and filters and the rest of what you posted sounds about right and I would replace the FICM with a HD 48V or a 58V, if it's not causeing any issues right now it probably will sooner or later..
imelmo
How much if you don't mind me asking? I need to find me one of these deals. I like the Camaro I got for a back-up vehicle but it's just not "me". LOL
fordfreak4life
Lacking mullet
Sent from my Milestone X2 using Tapatalk 2
Agjake11
Rosenberg TX
Nice find OP
theres a 05 ccsb 4x4 in college station with bad hpop and 150K for cheap right now. its doesnt need enough work to be a parts truck im looking for
Short Bus
kansas
I paid 7500 for it and it booked for 15-17k depending on condition. It needs a good vacuuming since the guy had a dog in it, but that's nothing major since it will be my German shepards new ride too. I didn't think about the oil cooler, anything else? It will be getting new fluids for sure, schaeffers front to back!
Derek@Vision Diesel
Canby, OR
Throw the "Blue Spring" kit in it from ford, worth it while you are there.
Replace the stand pipes and STC fitting as well, just some little things that don't cost much that will save you headache later on.
kyle43335
awh yes the magical blue spring,that costs around 65$
take the free route check psi under wot. if it doesnt loose pressure? leave it alone. if it does? strectch the spring alittle bit. free!!!
Derek@Vision Diesel
Canby, OR
Ive never paid quite that much, but if there is a free way to go about it then that is even better! Just a tip, a lot of higher mileage trucks through our shop gain something from doing it, no matter what way you go about it.
chappy
Marshall Mi
stc fitting on hpop for sure while its apart. Get rid of the plastic cold side pipe while you're getting stuff. We have stock trucks split them a lot at work.
Short Bus
kansas
Where's the best place to get hpop fitting, ic pipe, oil cooler and o-rings/ gaskets that I will need, ford? I'm getting everything else trough full force. What is everyone's thoughts on the ficm, was looking at getting one with the tow/ econo flash but wasn't sure about the higher voltage ones.
Snake
Flo Rida
Ford or Bulletproof Diesel. Not sure if you have a connection at Ford or not, but Sunrise Ford is a vendor here and offers a 25% discount and free shipping.
Check out the Bulletproof Diesel FICM's. I think you'll like what you find.....
Short Bus
kansas
Ok just ordered hpop stuff, oil cooler, ic pipe and egr gasket set from bullet proof.... Cab going up tomorrow and first bat ch of parts should be here tomorrow or Monday from full force
