bluedge8
It's hard to tell from your description whats going on. You have to completely different hydraulic systems in play here that technically don't connect to each other but are used together to complete your brake system. The power steering pump on your truck provides pressure to the steering gear and the hydraulic brake booster behind your master cylinder. It seems to me that one of 2 things is happening:
1: The power steering pump is not building or maintaining enough pressure to run both the steering and the booster at the same time, or the brake system is using way more pressure that it is supposed to to stop the truck.
or,
2: The master cylinder is not working correctly and is requiring way more pressure from the p/s pump to stop the truck which is bleeding off too much pressure from the p/s system and you can't turn the truck very well.
What I don't know is how to diag one vs the other and separate out the problems. I know brakes much better than hydro-boost so, In my opinion your brake pedal should not ever be able to go to the floor if the brakes are in good working order, so if it was mine I would work on the brakes first and the p/s system second, hope that helps.
or,
