My 2002 7.3 has been having a problem with the brakes sticking on me. I drive for about 10 minutes and the brakes are cool and work fine. Then after about 15-20 minutes of driving the brakes start holding pressure until the point of smoke rolling off the brakes if I drive it long enough.
The things I have done so far is replace all 4 calipers, rotors and brake pads. I also swapped all the rubber lines to stainless steel braided lines. I have taken the calipers off each wheel lubed the pins and made sure the pads slip in and out nice.
I can pull the truck in the shop jack it up put it in neutral the wheels are locked up solid and won't move. If I crack a bleeder open everything spins free like it should. I tried it over again this time cracking the lines at the master cylinder and the pressure stayed applied.(then I cracked the bleeder on the caliper and it spun free again) So I'm guessing it's before the master cylinder and hydro booster.
Anyone have and experiences, ideas or guesses what I should look at next? Thanks for any and all help!
