Brand new elite DIY 6.0 nozzles
Whitezotti
helotes texas
How does a nozzle make the injector a 170cc?
The 170 nozzles come with a kit . New orings. And the way it makes it 170 it plugs the spill port. It comes with plugs . Also it comes with a extra shim to place under the spool valve assembly. There is one there originally. And your suppose to add another to make 2 on each injector. I had the 155cc injectors . They are exactly the same. 155 nozzles and plugged spill port but it didn't come with the extra shim. That is the only difference I'm the 155cc and 170cc kit. Different nozzles and 170s come with a shim.
Whitezotti
helotes texas
Brand new outer orings and inner orings. For the whole injector including the spool valve assembly. And it comes with that metal retainer clip for the spool valve assembly to. Lastly it comes with 2 metal clips that allow you to hold your injector in the vise without damaging it.
