broken nozzle (kinda ot)
boggerr
Barnegat, N.J.
I have cat et, it just didn't tell me much. Luckily the engine can be on the stand in about 15 minutes. I guess I'll bust the valve cover off. I might just take a known good injector and swap each one until i can get it to stop.
What's the engine in? Usually when they crack a nozzle you will be able to see it. Everyone I have seen so far half the nozzle is gone. You should be able to do a injector cut out with the Cat ET, that will narrow it down to which cyl. it is. Anytime we had one with a cracked nozzle it would hydro lock after sitting also it would run for a little bit after the engine was shut off. They will dump fuel after the engine is shut off too
