BTS 4R100 Two Converters & PCS
bcdeutsch731
The trans is a BTS built 4R100 for a 2wd. I used this trans in my 1969 C10 Duramax Diesel. The case of the 4r100 is for the modular motor NOT the diesel. I sent this trans into Brian last winter and had him get it ready for this season. I have not used it since I got it back from Brian. When it was in too Brian he installed a 5r110 output shaft in it because I was having problems breaking them. Brian said the 5r110 output shaft is a lot stronger. I have two converters for this trans. One is a Precision Industries 443738-3H with steel stator upgrade. I had problems with the clutchs holding all the power and I was sick of sending it back to PI so I had a custom converter made for the 4r100. The shop that did the custom converter cut apart the PI converter and installed new clutchs in it. I have not used it since the clutchs were replaced. The custom converter has been working awesome. I was going to send it in and have them loosen it up a little. Right now it stalls right around 2800rpm. I get one free stall change so who ever buys this setup I can get it changed to what ever stall you want.
PCS trans computer with wire harness. I did need to make some changes to the wiring harness for my application so someone may have to buy the wiring harness from the PCS to trans. Mark Broviak spent a day working with me on the dyno and on the street to get the pcs all dialed in. I will send some of my trans tunes with it so you have a starting point.
TCI Outlaw shifter I used with this setup.
I'm selling everything for $5,000 plus shipping. That is less then the trans cost by it's self.
Feel free to ask any questions. Brett 630-234-7666 or [email protected]
Thanks
Brett
bcdeutsch731
Here are a couple more pics.
BOSS450
Concord, NC
Wish this deal came up two years ago. I'm having problems keeping my converter locked too. May be interested in that one. More info and proice dm?
bcdeutsch731
It has been a great converter for me. All I will say at this time is it was a local converter shop that made it and it was $2400.
