Mike@MPD
Lol YES
Thats just sick! Looks like I need to get in the 6.7 game quick![]()
Lol. I'm trying tooCome on in the water is fine.........
YesDang nice run. What track is that, Capital?
That moment when you are running 10.16 and realize next day rail pressure drops to 25k on 2.0 when it gets to higher rpm and drops to 19k
Truck already has 10mm stroker on the cp3 bracket so bentley is gonna work on something for me so we can move forward
Not sure of the numbers but I've been told they flow quite a bit better than dmax heads...Does anyone have flow numbers on stock 6.7 heads? How do those numbers compare to the other Powerstroke platforms?
Maybe a 15 pump in the valley as well?
I'm pretty sure the cp3 flows quite a bit more, especially being a stroker pump. But the cp4.2 makes the higher pressures2 cp4.2's from a 15 would probably answer all the questions.
If I'm not mistaken even with the 10mm stroker kit in a cp3, doesn't a stock cp4.2 flow more? My knowledge is sketchy on this for sure but I thought the cp3 was a single p&b and the 4.2 was a double p&b...
Someone can correct and school on those thoughts... Please.
It has a stroker cp3 ...
