Build thread, Triple Turbo 6.7L Race truck build
JDub
Hooper, Utah
Atmospheres are the same size, s300's with 67.7mm compressor with 80/73mm turbine wheels. The high pressure is bigger, its an s400 with 67.7mm compressor and 83/74mm turbine.
Sent from my DROID BIONIC using Tapatalk
Lysons
Paradise Valley, Alberta
But the real answer is Because race truck. Lol
Makes sense, thank you.
And yes, race truck. I understand 100% now, thanks LOL
JDub
Hooper, Utah
In a compound setup, you only move as much as your atmosphere moves, even in triples which is still a basic compound system.
An S480 moves around 120lbs/min. Those S367/7 atmos move around 90-92lbs/min each, so the atmosphere in this case will be around 180lbs-min. An S510 is just over 160lbs-min.
madman1234509
mayfield, ny
If two 67 fmw can flow 94 lbs/min each. Then it's probably close to what a 105mm flows. Depending on how efficient their plumbing is and what not.
Buddy@MPD
Glen Burnie, MD
At this point we are waiting for a few things to come back from the coaters. Once they are back the mad rush to get her done will begin. We have a few parts left up our sleves to throw on to her also.
