Built 1000+ Capable 6.7 $45,000
WhiteMamba_Scorpion
Selling my truck. Ready for a new project and it needs a new home with someone who wants a reliable 766hp daily driver with potential for 1000+ with a few simple changes. Please read the entire ad below for mod list and everything that comes with the truck for $45,000 (NO TRADES). There is easily $40k invested into this truck to make it an unbreakable weekend warrior.
Truck is located in Marietta, Ohio
2012 CCSB King Ranch
83,000 miles on truck
40,000 miles on built setup
766hp
1552tq
Truck has been meticulously maintained for 83,000 miles. Built motor and trans have 40,000 miles on them and have Lubrication Engineers fluid. Truck runs and drives great and has been on many road trips to diesel events in North Carolina, Georgia, Kentucky, etc. I would not hesitate to drive this truck across the country. Everything on this truck has been built by some of the best in the industry and I have receipts for every dollar spent on the truck. This truck is garage kept all winter and only gets driven on weekends. There is a lot of untapped potential if you put bigger injectors in it. Easily a 1000+ capable truck with some more fuel. KBB for a bone stock version is 38k so 45k is not unreasonable for what's is in this truck (40k+).
Please see the parts list below.
-H&S MiniMaxx
-Custom Tuning by Morgan Primm
-2015 Long Block
-Balanced rotating assembly
-Keyholed crank
-Billet RNR Connecting Rods
-H13 Extreme Duty Taper Wall Wrist Pins
-Stage 1 Chromoly Push Rods
-ARP Head Studs
-ARP main studs
-Elite Diesel Stage 2 Valvetrain
-Valve relief cut pistons and Ceramic coated
-Gapless rings
-Ported heads by RCD
-Elite Diesel Ported intake manifold
-HS Dual Fueler Kit
-Elite Diesel Turbo Kit with 39mm Precision wastegate
-Precision 6870 CEA
-AFE 5 inch straight pipe
-No Limit EGR ****** with flow through plate
-No Limit intercooler
-No Limit intake
-No Limit polished coolant tank
-Maryland Performance Diesel CCV kit
-2015 pump in the valley
-H&S low pressure fuel pump
-New 15% Injectors
-Remote fuel cooler mounted in bed
-Elite Diesel Extreme Duty Transmission
-Mag Hytec 6r140 pan
-One Up Offroad Traction Bars
-One Up Offroad ALAs with Updated HD joint
-One Up Offroad track rod joint
-3.73 Yukon Gears
-TrueTrac rear locker
-Rigid D2xl fog lights
-Anzo U-Bar Projector headlights
-Edge CTS2 for with EAS kit for Oil pressure, fuel pressure, EBP, Boost, EGT, and back up camera
-Mag Hytec diff covers front and rear
-Carli leveling kit
-BD Diesel adjustable track bar
-Bilstein 5100s
-Platinum 20s
-Tinted Windows
-Rockford Fosgate speakers
-AMP steps
-LineX bed liner
-LED bed lighting
-Rigid D2 backup lighting
Will also come with factory EGR, *** exhaust, with wiring harness, factory 3.31 gears front and rear, factory e locker, Undercover 1 piece bed cover, spare new unused 15% injector, left over Lubrication Engineers fluid for engine/trans/diffs, spare H&S duel fueler high pressure feed line, 5" AFE exhaust axle dump, FTE resonator, Diamond Eye 5" straight through muffler, stock intake, OEM head lights and tail lights.
Sent from my Galaxy S7
Strokersace
Towanda, KS
My gosh, what a clean nice pickup!
I wish I had the money and it was a long bed!
And thank you for posting all of the details and pictures. It is refreshing considering how often people rarely post decent pictures and/or limited info!
imelmo
Purely a curiosity question, but have you ever brought it to the track?
This sounds like a smokin' deal for somebody.
WhiteMamba_Scorpion
Yes. It did 12.4 @ 110mph at 8400lbs with a bad launch on 295 Nitto G2s. That was at DNRs event at Milan Dragway. I'd say with some good tires and harder launch itd be low 12s on the current setup with some tweaking.
Black AOD
Ohio
I have driven this truck. It's everything Pete says it is and the pictures don't do justice of how clean it is. GLWS buddy! Whoever gets it is getting my favorite CCSB 6.7 that's for sure
WhiteMamba_Scorpion
Nice truck! So...what’s the next project gonna be?
Haven't decided yet. I have some ideas but nothing is ever 100%
Thanks man.
8WR_ZJ
Awesome congrats I guess? A member here?
Sent from my SAMSUNG-SM-G870A using Tapatalk
Dam dude! That didnt last long for sale. But at that price it shouldnt have. That was a nice build for sure. Good luck on the next project man!
