built to 3/21/99 Wheel hub
Slate
Lafayette, IN
I have a question, I bought a wheel bearing assembly for my truck. It's a 4wd with 2 wheel ABS. My truck was built in 02/99 so it is E99 suspension. I was wanting to know if someone has replaced theirs. The new part came with 4 studs, but didn't have any nuts to bolt the stud to the knuckle.
What did you guys use for the nuts and where did you get them?
I believe the assembly now has bolts that bolt all the way through the knuckle to the bearing assembly.
Tree Trimmer
use the nuts you took off.
it is possible to get the studs out and re-use those as well, though its MUCH easier to just put in new ones.
Slate
Lafayette, IN
I wasn't sure if they would be the same thread count.
And I have manual hubs, with a manual t-case
Sent from my iPhone using tapatalk
