Bump steer problem
188slo50
If got a bump steer problem on my 05 every time it hits a dip in the road or uneven lane. I've checked for worn parts and can seem to see any problems, alignment was done but I'm not completely happy with the position of the steering wheel anyway so it may go back for that. Any ideas of where to start?
Betarocker
Sea to Sky, BC
Drop pitman arm and drop tracbar bracket? Draglink and tracbar same angle? Tracbar torqued to tight-as-eff?
Check to see if the bushings on both ends of the tracbar are not worn out
m_j
likely need an adjustable tracbar to center the dif but most important the angles need to match
