busy weekend
Pizza pig
MD
Just a few shots from my weekend playtime.. now I just need a turbo... :popcorn:
she's all buttoned up ready to drop the cab, called it quits for today
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
Pizza pig
MD
Looking good! nice avatar BTW
yeah buddy! classic..
Those are JJ's/Dozer's return and feed lines/fuel bowl delete lines, i sourced my own regulator (I have to have green LOL) and made my own pump and fuel filter setup with sump myself, but its basically what he offers... JJ is the freakin man thats for sure.
Ill get some better pics tomorrow when im awake before the cab comes back down
05wh250
hendersonville, nc
looks awesome im lookin at doing the same thing but mines got dual alternators, so..... cant quite figure out what to do about deleting the fuel bowl?
BlueWaffle
Grapevine, TX
must be nice to have a lift just to put in a RR system! I had to put that shiz in cab on...never again! Looks good man!
faster6.0
Before the cab comes down u might go ahead and replace those stock bellows on the up pipes if you plan on finding a turbo here soon- will save a alot of headache later..
I've got vibrant 100psi bellows in stock if u need some.
PTSUPERD
Very nice!!
Same hardline kit I will be using from Dozer's. Pump will be a Fass 150/180 base with a fuellab pump retroed in. Sump will be installed as well.
Looking good PP!
Pizza pig
MD
Thanks for the kind words fellas! Not just a fuel system she finally got the ARP Treatment this go around! I though about doing the y pipe wilth solid pipe and eliminating the bellows. We will see hiw it goes today
Pizza pig
MD
190/75 warrens with tsd tuning
176k miles on all stock bolts and gaskets, no signs of puking. I did one at a time to see if she'll hold!
Mdub707
Mohawk NY
I need to do something fuel system wise, but really need to figure out how to get around the fuel bowl and how I'm going to incorporate a true check valve into the system to go with my vegistroke... also trying to map out a regulated return setup but not sure that's going to work at all...
windrunner408
Looks good Greg. So is whole stock fuel system (lines, pump, and filter bowl) gone now?? I see you went with the standard A1000. Can't wait to hear how it works out for you. I'm also curious how running the two micron filter pre-pump is going to work out as well. I have heard that it is better to run it post-pump but I dont know if it matters truthfully. Best of luck man and looks great. BTW I really like the green regulator.
