I'm going to be working on my boost leaks soon, found two leak spots at two of the boots, and one intake plenum leaking.
Looking for some input here on new boots and some different clamps. Boots at the spider and intake plenums are an older set from Dieselsite. Boots at the intercooler are silicone (I'm running a 6.0L I/C). Boot clamps are all stock Ford clamps.
I've always had issues with blowing off the boots at the spider. It's gotten to the point now that one of the boots is sliced and leaking. It's holding on for dear life.
So I'm open for suggestions on a set of new boots and some better clamps, or even if double clamping has worked out. When I rip this apart and fix the leaks, I don't want to go back and chase down any more boost leaks or blown boots. I'm thinking about replacing all of the boots, even at the I/C, since one of those is sliced but not yet leaking.
A full kit that I can just order in one swoop would be ideal. Or I can piece together. I know Clay at Riffraff has a full set I can get, and I've heard good things about it. Or if there are other setups out there, I'm all ears. I'm seeing 40+ psi of boost now, so I need something that can handle that kind of pressure. Thanks.
