Cal-Tracs
ytee
I have a set of Cal-Tracs that I used on my 97 for about 5 months. Just did a rsk with Super Duty springs and I will not be reinstalling. 275.00 shipped
Chris
ytee
I am located in Roxana, IL just outside of St.Louis , MO. The Cal-Trac bars are around 20" give or take, They go from bottom of axle to a bracket on the front spring eye. I am going to go a different route with my new suspension. I had the bars on my 97 but I am not sure what all they will fit. I would bet if you call Calvert Racing they could tell you.
Chris
SouthFlstrokin'
Well you obs guys do SD leafspring swaps right? So then they should fit my SD....
Pm sent.
ytee
I took a pic of the Cal-Tracs today.
sc96ps
woodbury TN
thay only fit the OBS properly due to the width of the springs ...i did the masureing for the first set thay made .
sc96ps
woodbury TN
thay not realy wide enough to fit the springs properly. you would need to force them and i also think the bar length was shorter for the SD.
