Cam install
08strokin
Maryville TN
Hey guys I have a quick question I'm wanting to install a stage one cam in my truck and I was wondering do I have to drop the crank to remove and install the cam? It looks like the crank is in the way of removing the cam. Thanks in advance for your help guys!
08strokin
Maryville TN
Anyone know the torque spec and procedures with new tty bolts for the crankshaft adapter
HOOV3R
Central PA
Make sure it goes on in the exact same orientation. If not, the engine will end up with a vibration. The crank is balanced with that installed.
08strokin
Maryville TN
Yes sir I did, I marked it on th crankshaft before I took it off, I just got to pick up a dial indicator tomorrow to make sure it's centered. I appreciate the help guys.
