Dustball8504
The tunes loaded guys. Should be going for a drive soon. Results to follow
:rockon:
Well not the results we were hoping for. On the xrace tune I could only maintain 23,400psi rail pressure. That's with 60's, stock hpfp, Elite stage 2 low pressure system, ported rails. I was able to maintain rail pressure while cruising but once I layer into it it would drop to 22,600psi then climb to 23,400psi. Rail pressure would drop off and then pick up again so it was trying but there's just not enough volume output in that pump to keep up. That being said I would say xstreet is bordering on the limit of the stock pump. So theres the info you guys were looking for, sorry I didn't log the runs as I was busy keeping it on the road since it was a little slick were I was driving.
Ya that's what I thought to but back then they also said the stock pump couldn't fuel 60s. Mayne ill wait for the mew elite DIY kit. Dual fuelers is overkill for a daily driver and I don't trust the industrial pump
