Cant get truck fired back up
black6.4
I'm guessing its the pump or one of your under pump connectors isn't tight I bet if you give it a shot of start fluid it will start! If all your getting is that low of rp after cranking and priming I have seen this before I changed the hpfp and got rp right away truck ran fine started with fluid but would not start on its own
blk350on20s
Well the valve covers off awaiting a new rail sensor. I have very little hope but well see.
blk350on20s
Ya. I know. Just irritating. Ill do an update on everything. You guys have been a huge help so far. Did a ground test on the hpfp harness. Both vcv and pcv checked out. Resistance test was 3.0 and 2.8. Pressure at hpfp is good. Bout all i can really check.
kyle43335
did you source that that line to block the oil feed to the chargers,so you can start it without turbos on???
blk350on20s
Ordered it today buddy. Be here tomorrow. If this doesnt work im puttin my old harness and pump on and goin your route. Gonna be a nice trick for sure
blk350on20s
Sensor did not cure it. Had a guy come by with a scanner. Not getting hardly any rail pressure. Im putting my old pump in tomorrow night. Pumps commanding 990 kpag. Looks like its making nothing
mortal798
Michigan
Never mind... Tapatalk didn't update the thread until after I submitted the post.
If you need any other info, let me know. Hope you get it fixed quick!
fat-fingered from my EPIC 4G
