CCV to exhaust modification
Mine worked flawlessly from day 1. Maybe some day we'll get fancy, and have check valved venturi kits to vent enough for these diesel trucks. Until then, gotta stick with whatever you come up with similar to these deals. Just be sure you put it after any muffler/cat/dpf that may cause a restriction, or it'll be pumping additional pressure into the crank case.
what anles did you cut the end at and set it in the pipe at?
