6.0smokinstroker
- Joined
- Jun 6, 2013
- Messages
- 19
- Reaction score
- 0
Has anyone re routed this and where is the tube located any pics or info would be appreciated would like to keep this blowby out of my intercooler +system
pull it out of the intake, swivel the nozzle on the valve cover around so it's facing down and pop some heater hose on the end of it and run it out the bottom of the truck. takes about $10 and 15 minutes.
How much oil would you ever see out of the hose ? Wouldn't want that on a new concrete drive way
All you guys using heater hose are you having issues with it getting soft and haveing the oil vapor deteriorate the hose? Heater hose isnt made for oil and im not sure if the vapors are enough to soften the hose up.
You should never see any really. The factory breather is baffled IIRC. Most you'll get is a stinky smell and a little vapor, as long as the engine isn't whipped.
vapor build up=oil puddling
