Ccv ******
Mesa, AZ
I ordered a vibrant venturi today,and will hopefully be putting this all together here soon.
valvetick
Be careful how and where you run it. Sometimes you end up blowing oil through the turbo seals. If you make the ccv too restrictive then the blowby will take the next path of least resistance which are the piston seals in the turbo.
This can happen for many reasons... but most common I have seen.
Kink in hose
Too restrictive of hose and/or too long of run
putting a filter on the end of the hose
catch can filling up and restricting ccv
I think the amount of blowby has a lot to do with whether it will leak or not.
I unfortunately have a good amount blowby on by truck and I just dump mine straight down under the truck and it smokes a good amount... but I never smell it in the cab. LOL one night in a home depot parking lot while idling and check emails on my phone a guy ran over and ganged on my window... he thought something had just caught fire under my truck. It was no more blow by than usually but the way the light was hitting it made it look like a lot of smoke.
Charlie found this on my truck when tuning it about a year ago I had a little CCV filter on the end of the hose and it plugged up. Removed the filter and never had an issue again.
kwelch08
corpus christi TX
I understand just didn't know if anyone had tried it and if it replaced the ccv housing on the valve cover. I already have the catch can, and thought about using it with it if it was worth it.
Sent from my HTC One M9 using Tapatalk
cRaZy8
I dont understand what that MPD kit is trying to do with all those fittings?
Merc82
From what it looks like to me is that they machined a new piece to go in the valve cover to replace the plastic piece completely. I think that piece also adapts to AN to secure the hose to. Looks pretty.
