Changed Tuning - Drives Way Better - Lost a Lot of Fuel Economy
bpan
They don't look the prettiest but they sure get the job done.
The rear bracket, I got a welding shop to weld these onto the factory cast block.
The front brackets, I needed to put these on the side of the frame rail due to my aftermarket fuel tank hanging below the frame rail. I would do a design that welded to the bottom of the frame, and the axle tube next time if the fuel tank is not there. I worked with what I had.
And yes, I used tractor top links. I come from a farming family and a farming town, I am well aware of what these can and cannot handle. I have a friend running the same setup sled pulling with a 750hp Duramax.
EDIT: Not to sound like an ass, I just know there will be someone that will comment on that, bashing them.
Sportchassis06
You saved yourself alot of$$$!!
