old man dave
Did you pull the codes? Low ICP code wont cause it to run funny afterwards, but an overboost code will.
I'll go ahead and nip this one in the bud (because I'm sure some keyboard mechanic is going to say otherwise) by saying that an OBS WILL throw overboost codes.
I have had this issue with my truck and witnessed it with others. It will give you a CEL and then run rough until you shut the truck down and restart it.
Mine does NOT run rough after throwing a p0238 but that's one of the ways a '97 California is different than the Federal trucks. Your generalization is not correct and referring to others as "keyboard mechanics" can be considered offensive when you are WRONG.
You want a cookie?
