Stroked777
What do you mean rpm ramp?
So your only issue is rpm spikes now? No weird noises or vibrations from the clutch?
My Rpms spoke too if I hit the theottle just right. I would think its a tps issue
Mine is auto. The Rpms will stay up until I tap the throttle again. Kinda scares you when you wanna creep up in traffic and you hit it and then jumps in Rpms causing you to move more than you want lol. But it's something that doesn't really bother me because it happen rarely
I had 09 6.4 6spd that would do the same rpm jump occasionally when in neutral and hit the throttle...
I wanna say it's a issue with your throttle position sensor
Look at throttle position and slowly press the pedal and see if there is any dead spots or spots that it jumps up in percetage or voltage (what ever you get a reading in). I Bet there is another way to test it but I don't know of any other way.
Could borrow a pedal from a buddies truck and see if it does the same thing
