creecher73
went to get in my truck started it up pushed in on the clutch pedal and can not put my truck in gear. turn the truck off put trans in gear and start it up the truck tries to take off, but can not shift it out of gear. so far i've changed the slave cylinder, and checked the measurements on things that Ben and Nate at Unlimited Diesel told me to look at, the arm on the slave cylinder is only coming out about 3/4" and if i remember right Ben said it should be about 1.5". havent been able to get off work early enough to get to the shop and talk to them in a couple weeks. So i was hoping maybe some of you have had similar problems and can point me in a certain direction. also i had no problems at all with the truck when i parked it. any help is much appreciated. truck is a 1996 F350
