coil conversion
06-sixoh
Bakersfield
Oh wow! Lots of info fellas! I havent gotten the truck yet, but everything is still a go. I do want to lift it about 4", so i might be ok on the drag links. When lifting it, do i essentially need to buy two lift kits?
FrankTheTank
Cecil County, MD
Why two lift kits? You just buy a lift kit fir thi size desired. Keep in mind that the axle swsp itself will lift you truck 3" over a stock 250.
kmanxj
Reed City, MI
I never heard the trimming drag link thing. Glad this thread was here or else I would have learned the hard way.
Strokersace
Towanda, KS
Interestingly enough my 05 conversion went in with zero modifications, 100% factory parts and stock height.
Except for the modified factory track bar bracket, countless holes you had to drill, welding on a bracket to the cross member for the steering stabilizer, etc...
I studied your pictures of the bronco for hours before I started mine.
Sent from my XT1080 using Tapatalk
