John@Outlaw_Diesel
I have a complete Regulated return fuel system for sale. IT is brand new in the box. Never used!
Comes with everything needed for complete fuel system to support about 600hp.
Both filters and bases are napa 1/2 ports on the bases
5/8 Irate Diesel pick up tube
5/8 hose to first filter base
1/2 from filter to Walbro pump
1/2 to second filter then
1/2 to the Y, then
3/8 to the back of the heads, with the correct fittings for superduty's
It then has 3/8 fittings for the Fuel lab regulator, then the factory feed line is used as the return
The whole system uses all push lock hose and fittings. Very high quality kit.
The kit uses custom mount that should work on just about any 7.3l psd truck. Would fit best on EC or crewcab short bed. There should also be enough hose for a cclb.
I have $725 just in parts to build the kit, let alone time took to build the mount and trips to the store.
I would like to sell it for $725 shipped. If you are worried about installing it your self, I can right out instructions on how to install it.
I wish I could install it on my truck, just don't have the time and could use the money right now.
I'm sure I may left out some details, Please call John@317-691-0447. I can text message pictures also.
1/2 to the Y, then
